Показано с 21 по 29 из 29
Тема: T-72 Build Tread (for our Colleagues abroad)
    The standard IR Receiver by DeA is not good, I would say. Too huge... Beside visual realization of the hits received is not implemented according to our general rules and standard. So in future it will be necessary to re-make it.
    But at the moment I re-made IR receiver only. Looks better now.
    1) Dea standard one
    2) Re-made version. Steps how to re-make it.
    And connecting boards to be allocated....
    Turret rotation mechanism.
    As said above, HL standard fits as well...
    So to continue... What about the gear?
    As our compare shows, the standard black or zinc, or plastic gear by HL will fit DeA T-72. This DeA gear:
    compare
    they are the same...
    DeA gear is without motor.
    Now we put gear inside the low hull...
    The difference is in the gear positioning inside the hull - it is not 100% horizontal. It is slightly angled.
    The hull and chassis.
    Hull is done out of very good even brilliant plastic. All details molded extremely well, all details are seen clearly.
    Chassis it self is ok, done out of plastic. No off-road driving. Driving wheel (sprocket) is out of metal, idlers are also done of metal& Good quality.
    Rubber tires cover the road wheels
    Extra fuel tanks...
    and front lower panel
    Putting tracks on...
    And OFF-WE-GO!!!
  1. Hooben T 55 build
    от sevoblast в разделе от Т-44 до 1991 года
    Ответов: 40
    Последнее сообщение: 24.09.2017, 18:55
